The charge 2 is supposed to track sleep stages/modes like REM DEEP SLEEP LIGHT SLEEP but all that it shows is awake, restless, sleep but I am sleeping longer than 3 hours so can someone help me
Best AnswerNvm found answer for those who also need help ill give you a quote and a link to help you 🙂
There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
@MissiontoMars12 thanks for sharing and finding the answer.. I marked your entry as a solution so it can help others. Thank you!
Elena | Pennsylvania
Best AnswerDo you know if putting your phone in flight mode affects this? I don’t like having my phone on or not in flight mode while I sleep, however even with sleep sensitivity on instead of normal, I only get results that look like the one from the normal setting (awake-restless-asleep). I want to see all my sleep stages though... any advice?
