Charge HR Sleep: Anyone elses give you two entries, neither accurate?
Anyone else getting multiple sleep logs for one night?
Both started at the same time (930pm), one ended at 1am the other at 620 am.  The one with 1am end time had no data so I delete it.  Now I show 5.25 hours of sleep even though I slept closer to 9.
Confusing and frustrating.
Hebba from Massachusetts
Start Weight: 224 lbs Last Weight:213.5 lbs Total Loss: 10.5 lbs (as 12/9/2015)
1 REPLY 1
@hebba Yes, it is a pain. I get on average three/night and the gap on some is only 1 minute. Because I export the data and only one record exports I edit the records.
In my case I delete the 2 youngest records and then I edit the first record to show the correct sleep period.
All is correct then, because you were wearing your Fitbit. Give that a try.
Try that.
Colin:Victoria, Australia
