I've had my FitBit Charge HR for a few weeks now. I assume it uses movement (or lack thereof) and heart rate to track my sleep. What I've found is it takes about 2 hours before it thinks I'm asleep. For instance, if I go to sleep about 10:30pm it says I went to sleep about 12:30am. The wake up time is pretty accurate.
I would like the ability to edit the sleep record in order to make it more accurate, but I'm unable to do so. When I edit the record to reflect the correct time, it says I already have a sleep record for that time. Should I delete the sleep record and create a new one? Will it still show the 'restless' or 'awake' times if I do that?
Thanks!
Thad
Best AnswerIt is possible to edit your sleep log on the dashboard. I use a laptop for this, not the app. On your dashboard, go to the top of the page where it says 'log' select sleep and scroll down to where you see the graph of your sleep. Hover on the graph and on the right hand side of that square there will be a gray paper/pen icon indicating you can edit the log. Click and edit as you like. Fitbit will adjust all your data accordingly.
Best AnswerThat's exactly what I'm doing. It allows me to 'edit' and I adjust the 'entered bed' time. When I click 'update' I get the message that a sleep record already exists at that time.
I've tried this on the iOS app as well and get an error message. It's just not allowing me to edit the times.....
Thad
Best AnswerSo, I deleted the sleep record from last night. I tried to create a new record with the correct times and here's a picture of what happens:
There are no sleep records for this time; I deleted the one I could not edit.......
Thad
