Looked at HR from the sleep the night before and noticed it was insanely higher than normel. Normal sleeping is 60ish. For around 5 hours, it was around 140 - 160. Not sure if it was a glitch or I'm fixing to stroke out?
Was it a one-off event, or have you witnessed something similar over several nights? You can display the 24-hour HR graph for any given day in the mobile app. You may also want to restart your tracker.
Dominique | Finland
