09-28-2018 16:39
09-28-2018 16:39
Best Answer10-07-2018 09:54
10-07-2018 09:54
Hi @Kyleer I'm sorry to hear you are having an issue with tracking your sleep. Have you tried deleting the auto tracking data and manually entering the start and end time of sleep? Occasionally I have an issue with sleep data and deleting and manually entering start and end fix the issues. The system information will populate with you manually enter the start and end. I also find if I have to do this a couple of time, the issue doesn't persist and every thing works correctly. I hope that helps.
Best Answer10-07-2018 14:03
10-07-2018 14:03
Hi Marcy, Thankyou will give that a go.
