05-16-2016 10:37
05-16-2016 10:37
I am new (less than 1 week) to Fitbit. I have a Surge and was encouraged by my coworker to get a premium account. With all that I can't figure out how to get a heart rate plot with an arbitrary start and stop time from the collected data. I have looked in the main website client, and in the Android app, and although I have heart rate graphs for defined exercise sessions, I can't find a way to show them for sleep sessions, or for any arbitrary time period, e.g. sitting in meetings, etc. Please point the way for me. A thousand thanks.
Best Answer05-17-2016 17:23
05-17-2016 17:23
Doctari Welcome, you can create a Custom Activity and I called mine Surge Sleep HR. When you enter the data you will probably find on the PC you will need to enter the calories but on the Android it gives you the calories.
Just type the description into the Activity Log view and that will prompt you to create the activity.
If you do this analysis for other periods of the day it levels the calories over the time period and you may lose Active Minutes.
Here is a sleep example comparing my Charge HR and the Surge
@SunsetRunner wrote:I am new (less than 1 week) to Fitbit. I have a Surge and was encouraged by my coworker to get a premium account. With all that I can't figure out how to get a heart rate plot with an arbitrary start and stop time from the collected data. I have looked in the main website client, and in the Android app, and although I have heart rate graphs for defined exercise sessions, I can't find a way to show them for sleep sessions, or for any arbitrary time period, e.g. sitting in meetings, etc. Please point the way for me. A thousand thanks.
Best Answer05-18-2016 14:17
05-18-2016 14:17
Thanks very much. I found where to create a custom activityand made one called Surge Sleep. I will try to activate it tonight. Great idea.
Best Answer05-18-2016 16:00
05-18-2016 16:00
Best Answer05-18-2016 16:51
05-18-2016 16:51
@Doctari To add to my earlier posts here is a link to another area where I showed how you can "home" in on a particular area of your HR.
