02-21-2024 00:19 - edited 02-21-2024 00:20
Is there a way to view deep sleep over time in a graph or chart without going into each day individually and checkign the sleep breakdown?
Is there a way to import the raw data to PC in the form of x.xls etc so I can extrapolate this data.
Thanks.
Best Answer05-28-2024 00:03
05-28-2024 00:03
Theoretically it would be possible using the API from the dev section, but it's beyond my skill level. If you're into programming, maybe take a look at what the API exposes:
https://dev.fitbit.com/build/reference/web-api/sleep/get-sleep-log-list/
Best Answer05-30-2024 16:32
05-30-2024 16:32
Hello. If you go to the sleep tab on the app, at the top you see Day, Week, Month Year. Click on on of those and you will see a graph and under it you can toggle between, duration, score, schedule and, on the right, sleep stages. There you can see a drop down menu and check each stage for any of the periods at the top. I have to say, I have been reading all the dislike for the new sleep layout, but I don't think there is anything missing from before. Granted I don't think change was needed at all and probably prefer the old layout rather than what seems like change for change's sake, but I don't think in terms of what it shows it is a big change. This is my first post, but I promise I'm not a fitbit plant trying to defend the new sleep layout!
