10-08-2019 17:58 - edited 10-09-2019 07:41
According to this article by Fitbit, most users earn a sleep score between 72-83. Since the score is out of 100, and the display on iOS shows up as a circle that I have failed to close, I am wondering if anyone has ever actually earned a sleep score of 100. Is it actually possible to achieve this goal? If so, how? Were strong sleeping pills involved?
(Edit to add: No, I do not take sleeping pills, I do not drink, and I do not want to take any substances. I made this comment because I believe the scoring system sets an impossible standard. And no, I am not buying premium just to see the math).
Honestly, even on a night when I slept for over 10 hours with plenty of deep sleep, my “score” was still only an 84. It seems impossible to earn above the low 80s.
It feels like I am taking one of those impossible “weed-out” classes in college where nobody earns above a B- and the prof doesn’t give As on principle. Is that the model here?
If it’s not really possible to get a sleep score of 100, why is the sleep score configured to look like an achievable “goal” from which we have somehow fallen short? If we are doing everything in our power to get good sleep, and we still cannot earn 100 or even 90, what’s the point of it? Fitbit has been so useful for helping me to set and reach goals. Why create a goal that is inherently unattainable?
06-04-2020 21:18
06-04-2020 21:18
I’ve been wondering too. Is the sleep score adjusted for age? If I am awake less, in the range for REM and deep sleep for my age, then isn’t that better than “fair” or “good”?
06-07-2020 01:43
06-07-2020 01:43
Hi Thanks for the info.
Just wondering when you get over 91 does you score go from "good" to "v good" or something like that?
Robbie
06-07-2020 01:53
06-07-2020 01:53
From 90 it is “Excellent”.
06-07-2020 02:34
06-07-2020 02:34
My best is 85 in early Autumn.. I will never get higher than that because, in Winter, sleeping at night with extra blankets and the same RHR as Autumn, my HR goes above well above because I have a low RHR. I'm typically getting a score of 13 on the restoration graph where I was getting 20 in Autumn with the same RHR.. A penalty of 7 points to keep warm.
Others have posted about this anomoly but I'm not going to deny warmth in Winter.
06-07-2020 03:43
06-07-2020 03:43
06-17-2020 16:11
06-17-2020 16:11
Hello, I’m new to the Fitbit, I am a 54 year old female and although I am quite active I definitely need to take more exercise. I got mine a couple of days ago and sleep scored 85 on the first night then 90 last night. I must say I was surprised at such high scores as I don’t have a curtain at the window near my head so the room gets light very early. I got my Fitbit to help encourage me to stop smoking, I’ve smoked cigarettes for 40 years, I smoke around 20 roll-ups per day. This obviously shows that you certainly don’t have to be fit (unless I am fitter than I should be) to get high sleep scores. I will be very interested to see what my scores are when I finally stop smoking.
06-27-2020 08:19
06-27-2020 08:19
I’m pretty sure the time asleep is based on the goal you set for yourself so it is specific to each user.
i have been trying to figure out exactly how the time asleep portion of the score works though as I haven’t been able to score over 46/50 — I think if you hit your time asleep goal, you get the 50 and then you lose 1 point for every 15 minutes that you’re awake? I typically am awake for just over an hour and score 45 and then on the nights where I’m awake for 50 some minutes, I’m up to 46. Can anyone confirm if this theory works with their scores?
07-17-2020 09:34 - edited 07-17-2020 09:42
@Yennnny . I have always pondered over this question many times. I have days that i have had not so restful sleep and scored in the high eighties and have slept like a log and have scored in the 70s. I am still consciously looking at the sleep scores. But more than that what Fitbit Sleep App has done for me is to look beyond the sleep numbers and has gotten me into a habit of sleeping close to my target sleep time and wake up time everyday. And i am already reaping huge rewards because of it. I am mentally more alert and i am able to go from idle to sprint in a fraction of seconds. I love the Fitbit Ionic and all the features but most importantly the sleep app. It has allowed me to drop my resting heart rate from low 60s to low 50s now. And i was able to do that only because of 8 hours of sleep everyday. I have worked out like crazy and have had 7 hours of sleep and it increases my resting heartbeat by 2-3 points. But if don't work out but get 8 or 8 plus hours of sleep it brings my resting heart beat from high 50s to low 50s. And that is absolutely fascinating for me. So i have stopped looking too much into the numbers but just try to maintain 8 hours sleep. Hope this helps in the whole scheme of things Good luck 👍!
07-29-2020 09:11
07-29-2020 09:11
But I’ve been looking for how those norms were created and how they break down the age groups, which is what brought me back here. So far after looking for a while, can’t find any article that rigorously set up the norms. I know enough about statistics to know that one needs to do such a thing with scientific rigor.
07-29-2020 09:25 - edited 07-29-2020 09:25
@LM66 Very interesting.. I mean you hit 90...the highest i ever hit was 88 and i was exhilarated 😀
But i think you are on the right track but like you said it will be definitely be interesting to see how your scores look when you completely stop smoking. Best of luck👍
07-29-2020 09:28
07-29-2020 09:28
@Eileen690 Very true..the less red you have the better the sleep numbers and also the red should be hairline thin and not wide is what i believe. Because without you knowing you can be awake for a bit here and there in the night and that is totally normal. But say you pull a cramp or nursing an injury those red marks are wider means your total sleep score is a bit less. I find the sleep study so fascinating 😀
07-29-2020 09:33
07-29-2020 09:33
@Colinm39 Just have question for you if you don't mind answering? I believe that you run a lot from the definition of your profile so does a rest day give you better sleep numbers than a run day? I have also seen that on a rest day my RHR is around lower 50s and on a run day(1-2 miles) my RHR is higher? Again everybody's body is different so i am making no assumptions here. Thank you and cheers!
07-29-2020 09:46
07-29-2020 09:46
07-29-2020 10:08
07-29-2020 10:08
07-29-2020 10:09
07-29-2020 10:09
07-29-2020 10:15
07-29-2020 10:15
07-29-2020 10:19
07-29-2020 10:19
07-29-2020 10:26
07-29-2020 10:26
07-29-2020 10:50
07-29-2020 10:50
07-29-2020 10:54
07-29-2020 10:54
