02-08-2018 06:03
02-08-2018 06:03
Is the technology used for sleep tracking the same in Charge 2 compared to Alta HR? Some sources indicate that the the Alta HR is more up-to-date regarding sleep-tracking than the Charge 2? Is this so?
Best Answer02-08-2018 11:58
02-08-2018 11:58
No worries. Sleep stages from Fitbit were often associated with the release of the Alta HR, which I think caused some to mistakenly believe the Alta HR had more updated technology.
Basically, whichever tracker you can wear comfortably so that heart rate monitoring is continuous without dropouts, is going to give you the best results.
Best Answer02-08-2018 08:08
02-08-2018 09:39
02-08-2018 09:39
02-08-2018 11:58
