02-03-2021
12:40
08:25
WilsonFitbit
02-03-2021
12:40
08:25
WilsonFitbit
Quick question and I'm hoping you can point me in the right direction.
Is there a meaningful difference in sleep reporting data between the Fitbit Inspire 2, the Fitbit Charge 4 and the Fitbit Versa 3? Thank you.
Hello @jonathankahan, welcome to the community forums!
It is possible that if you wear more than one Fitbit device when you go to bed, there might be slightly differences between the sleep data, but this could be caused due to the position the devices are worn. But overall, your sleep data should be tracked in the same way since all wrist-based Fitbit devices automatically detect your sleep. We recommend wearing the Fitbit device you have, in a snug wristband while sleeping; don’t wear your device in a clip or pendant accessory.
For more information, I recommend checking the following link: How do I track my sleep with my Fitbit device?
Hope this helps!
