10-02-2018 23:14
10-02-2018 23:14
Best Answer04-28-2020 05:23
04-28-2020 05:23
If your budget is low, don’t go with the cheapest option you find. As much as I know, a good mattress is at least $400. Don't go lower because the quality drop-off will be huge.
Best Answer04-28-2020 08:24 - edited 04-30-2020 08:12
How low is your budget? The question appears because as much as I know, a good mattress is pretty expensive. I bought a new mattress last year, and I chose the memory foam. It looked at the best reviews on sleepauthorities.com. and as much as I know this website has real reviews. My opinion is, you should invest in a good mattress, because it will serve you for many years and it's good for your back. At least, don't go with the cheapest option, I'm sure you'll regret afterwards.
Best Answer04-29-2020 20:19
04-29-2020 20:19
You should be aware that there's really no way of telling if a mattress listed online will be right for you. It's too personal an experience. Reviews could say the mattress is firm for them, but could be too soft for you. I purchased one online that reviews said was a good mix between soft and firm. But when it arrived, it was like sleeping on a rock. Returning a mattress online is no fun either. 😞
I'd recommend going to a bunch of real-life stores (when they're open again), and test out a bunch of mattresses. When you find a model that you feel comfortable with, then locate it online and buy that one.
Best Answer05-07-2020 11:58
05-07-2020 11:58
Thanks and amazing suggestion.. I am New member here Sahil Gogna.. i was also looking fitbit watches for my taxi melbourne company employees.
Best Answer06-09-2020 21:28 - edited 06-09-2020 21:30
That’s a tough question.
Depends on your weight and what works for your body.
i Love my purple mattress, but it is soo heavy - won’t be moving it till I have to. But does give me back aches once in a while when I sleep more than 10 hours, since my body weight is under what is optimal for this mattress.
but I love it because it puts me to sleep immediately and I have insomnia. And when I wake up on a regular sleep night I feel super energized.
(found out after receiving it that it’s for ppl who weigh more than 140 lbs & I sleep 10+ hours on weekends bc I sleep 4 hours a night during the weeknights)
Best Answer06-12-2020 11:15
06-12-2020 11:15
I really need to get one of those orthopedic mattresses 😁; my father got one a few months ago and it's been very helpful for him and his back pain.
A good mattress and pillow that work for you can really make a huge difference on sleep quality!
