On line manual for how to set up sleep mode for flex?Betsey
How do I find an online manual to set up my flex sleep mode? I am figuring out pretty much everything else.
Betsey
1 REPLY 1
Sleep mode can be tricky. It needs to be taunt against your skin.
Five rapid and firm taps puts it to sleep. It buzzes, then two lights slowly fade to nothing. To check if it's still in sleep mode, tap and see two dancing lights.
In the morning, tap five times firmly and it buzzes and a single light shows when tapped. That light is to show the daily goal progress. Any tap when awake is to tell you your progress - one light for each 20% of your goal.
When you sync the next time, it ought to log your sleep.
click to read about sleep tracking
This link is to the Flex area where you will find the manual and related articles - click
Stepping in the U.S.A. since September 2013. Android 14
