New Sleep Cycle Alarm Clock allowing to increase precision of sleeping in 90 minute cycles:
https://itunes.apple.com/us/app/alarm-clock-sleep-with-sheep/id1219978190?l=pl&ls=1&mt=8
Description from iTunes:
Will you dare to Sleep With Sheep?
Don't answer yet.
First, think of a good sleep as an investment with a high rate of return.
Second, embrace a widely acclaimed life hack: sleeping in 90 minute cycles.
Third, imagine an app that can make this life hack work better than any other.
Fourth, counting sheep is overrated.
So, what can you expect from the app?
* Contrary to other apps this one increases your chances of waking up refreshed and full of energy exactly at the end of a 90 minute cycle (between REM phases) in an extraordinary fashion.
* Using the app may help you establish effective sleep patterns and make you become more self-aware of your sleeping habbits.
* You can generate some EXTRA TIME since 90 minute sleeping scenarios will often make you wake up earlier than you have to.
* You can easily rate each sleeping session and analyze stats so that over time you will learn which sleeping scenarios suit you best.
Check out the formula:
Wake Up Time = Current Time + I will fall asleep in about (...) + 90 Minute Sleeping Scenario
90 Minute Sleeping Scenarios are as follows:
- Quick Ninja Nap (90 minutes / 1.5 hours)
- Sheep On The Moon (180 minutes / 3.0 hours)
- Early Subway Ride (270 minutes / 4.5 hours)
- Refreshed Einstein (360 minutes / 6.0 hours)
- Busy, Busy Multitasker (450 minutes / 7.5 hours)
- Sleep Like A Baby (540 minutes / 9.0 hours)
The challenge is real. And The Sheep is staring at you. No pressure.
