04-26-2021 20:44
04-26-2021 20:44
Fitbit Team,
Have a great day.
I cannot use electronics on the water heating system. The water valve not work with NEST and Honeywell thermostats. I get child at room temperature. I put up the heat. I sleep with only socks. This is not helping. I have a 20 lbs weighted blanket, many times I have the blanket aside, anxiety, restless sleep, etc.
Thank you for your time.
Charles Allen Martin
P.S. Sleep S Med+ kept saying bedroom to hot. It is in the storage room in the box.
04-28-2021 16:53
04-28-2021 16:53
@CAM345 - I’m not sure I understand your question. Do you own a Fitbit device or are you looking for advice on sleeping better? I’d be happy to offer a few suggestions on what helps me get a better night’s sleep:
Hopes this helps.
04-28-2021 19:14
04-28-2021 19:14
Carol B, Michigan,
I have a Fitbit Charger 4. I wear it almost 24 hours, only a shower take it off.
My thinking is at the grade 9 level.
04-30-2021 19:37 - edited 05-28-2021 19:28
It would not be hard to add a relay so the thermostat can control your heater. An electrician can easily do this.
Best Answer04-30-2021 21:12
04-30-2021 21:12
Hello @CAM345
I'm not sure I understand clearly, but if I do, I think this is something you're probably better off calling an electrician, or a heater maintenance person for instead of asking fitbit?
Regards,
Bart
