Hello!!!!
I have the Charge2 device, can someone have the sleep stages mode working properly???
In my device, it doesn't work... 2 nights with no stages monitoring and 1 night ok, it works... the next one it doesn't work again. I read some posts here but no answer....
Hello to you too!
From this article about sleep stages:
Why don't I see sleep stages today?
There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
I hope this helps!
Karolien | The Netherlands
Hello to you too!
I hope this helps!
Hello,
Tks for your reply!!
The problem was that I used the Begin Sleep Now option.
Now, I am not using this option and it is working!!!
Regards,
Tiago Facchin
