11-17-2023 22:38
11-17-2023 22:38
Hi all,
I have been using my fitbit for a while and I don't know if I have strange sleeping patter or if the fitbit is registrating every move. It seems that I'm awakining a lot during the night, around 30 times, and get very little deep sleep, between 10 to 20 minutes and this is how it is every night. Is this normal? How does your sleeping patterns looks like.
Best Answer11-18-2023 14:38
11-18-2023 14:38
Hello @Sinivanni123
Please keep in mind that everyone's sleep pattern will be different. That said, my sleeping pattern isn't too different than yours that you shared. Our Fitbit devices track our movements during the night. If we're a bit restless, it will show that we were "awake" during that time even though we don't actually wake up.
There are nights when I don't get a lot of deep sleep. The important thing for me is how I feel in the morning. If I feel rested and not tired, I don't worry too much about my tracked sleep pattern.
If you think you are having a sleep issue and are not getting enough sleep, you should discuss this with your doctor. They are the best person to give you advice.
Best Answer11-21-2023 21:54
11-21-2023 21:54
Hello RiekoC,
Thank you so much for your answer. I feel a bit rested in the mornings, so maybe there is not an issue.
11-21-2023 21:55
11-21-2023 21:55
Thank you dianaadrr.
Best Answer11-22-2023 14:05
11-22-2023 14:05
You're very welcome. Glad to hear that you feel rested in the morning.
BTW, I forgot to mention about Sleep Sensitivity. You might want to check to see if your Sleep Sensitivity is set to Normal or Sensitive. If it's set to Sensitive, I believe it will track more awakenings. To check:
Just to let you know, my Sleep Sensitivity is set to Normal and I still see a lot of times where my Fitbit tracked an "awake" time during my sleep.
