04-12-2017 09:08 - edited 04-12-2017 09:08
I just started using my fitbit a few days ago, and I pretty much ignored the sleep tracking, even though it said I only got 5 hours of sleep a night. But I recently read that getting less than 6 hours of sleep significantly increases the risk of obesity, and that getting 7-8 hours of sleep a night helps your body lose weight as well as maintain weight loss.
Has anyone experienced this? Because if so, I might have to start changing a few more habits!
04-13-2017 07:33 - edited 04-13-2017 07:37
@modelinafatgirl: Research shows not enough sleep leads to weight gain. It lowers your energy level and boosts hunger and so on. Also it leads to various illness. Check this article. Here is another study done in UK few years ago.
Try to get minimum 7 hours of sleep.
04-12-2017 11:18
04-12-2017 11:18
I can't say it's a direct correlation, however, when I'm not sleeping well my energy levels can be lower. Because of work commitments my sleep has been lower the last couple of weeks. I can usually get up early and workout without any trouble. However, this week It's been a disaster - getting over 8 hours on Saturday night (high for me), then just over 5 hrs on Sunday, not even 3 hrs on Monday - and I didn't get my tracker synced this morning before I left home. However, I couldn't drag myself out of bed to do any kind of workout, so now I'll have to do it tonight.
Some people run very well on lower sleep. In fact I'm pretty sure I did when I was 20 or maybe even 30 years younger.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
04-12-2017 12:55
04-12-2017 12:55
I have the same problem -- working out is always harder when I'm tired. Okay, I guess I'm adding sleep to my goals!
04-12-2017 14:16
04-12-2017 14:16
When you are tired you also tend to overeat if you are not careful. The body has a hard time regulating hormones and therefore we crave junk food more.
Karolien | The Netherlands
04-13-2017 09:26
