07-16-2020 16:43
07-16-2020 16:43
Does anyone have a problem with your band getting tight while sleeping?
07-29-2020 12:03
07-29-2020 12:03
Hi, welcome to the Fitbit Community @Acea!
I wouldn't use it too loose, becase it could affect the heart rate accuracy, but it shouldn't be too tight either.
Could you provide a few extra details of what you've been experiencing? Do you feel the Fitbit device is tighter by the time you wake up?
Here you can find some extra recommendations on how to use the device to sleep better as well.
Keep me posted.
Best Answer08-01-2020 07:29
08-01-2020 07:29
08-02-2020 10:31
08-02-2020 10:31
@Acea you may be retaining water during your sleep which is causing your limbs to swell. Make sure you are hydrated through out the day to ensure you don't have a bunch of salt stored up and make sure you tinkle before bed. If it still causes discomfort, as much as you would want sleep data, it may not be a good option for you...
Elena | Pennsylvania
