04-28-2014 16:41
04-28-2014 16:41
Also is there any way to know if I am in Deep sleep?
Best Answer04-28-2014 16:49
04-28-2014 16:49
If the FitBit senses you moving around (tossing and turning, changing sleeping positions) it marks that as restless sleep. A full night of that, and you aren't going to be well rested in the morning...
Not sure on this, but I imagine if you go a long period with no movement it would mark that as deep sleep.
Best Answer04-28-2014 18:19
04-28-2014 18:19
I've had sleep tests done, and the FitBit matches the results of the doctor's tests, so it's pretty reliable. If you are getting "restless" feedback, you may want to check in w/ your doctor to see if you should have a sleep test performed. Sleeping w/ a machine can make a world of difference in your life, especially energy! Good luck!
Best Answer12-28-2015 09:42
12-28-2015 09:42
I'm new to fitbit and all the feedback information it provides about my sleep, restlessness and activity but I'm not sure how I benefit from knowing I had 29 restless moments last night. What do I do with this information?
