04-28-2015 16:32
04-28-2015 16:32
I have tracked my sleep for two nights so far. Both nights, in normal setting, say I slept about 6.5 hours, with many interruptions or restless/awakened times. 17 x the first night and 20 x the second night. I switched over to Sensitive setting and looked at the graph ---- WOW! It says I really slept for a mere 3 hours and 39 minutes and was awakened 10 times. Last night, I was lying awake for a long time...I remember it clearly because I actually got up and went downstairs to get two sleep aid pills. I couldn't stand it anymore and was sick of just lying there awake! In the normal mode, it doesn't reflect that. In the sensitive mode it clearly shows I was awake for the time frame I remember being awake. However, I have no idea how I can function ( went to work) on 3 hours and 39 min. of sleep, interrupted to boot! Your thoughts on these two settings pretty please and thank you!
04-28-2015 21:59
04-28-2015 21:59
I would like to know also!! Significant difference in sleep tracked with these two functions.
Best Answer05-24-2015 19:00
05-24-2015 19:00
One of the biggest reasons I wanted a Fitbit was for the sleep tracker.
For the first 3 or 4 days I had mine set to normal and I was seeing 80-95% efficencies with 25-40 minutes of restlessness. I noticed that according to the graph on the iPhone Fitbit App that I hadn't "awaken" at all even though I specifically remember opening my eyes a few times to move into a more comfortable position.
One night I set it to sensitive and I got a really low efficiency and only 4 hours of sleep. I didn't feel like I got such poor sleep, I actually felt really good when I woke up. That was the only time I had it on sensitive and I've been using normal ever since.
As weird as it might sound, sometimes if you see that you have "poor sleep" according to a graph then you start to feel like you got poor sleep, even if you actually got great sleep. Our minds are very powerful that way. So I choose to use normal because it does show the amount of times I'm restless (which I know is true because I remember moving in the night but I fall back asleep quickly) and it says I get 7-8 hours of sleep a night which reflects how I feel each morning.
I think the reason there are two settings is because everyone is different. For me, normal setting is better.
