01-22-2014 08:21
01-22-2014 08:21
Best Answer01-22-2014 11:05
01-22-2014 11:05
Best Answer01-22-2014 15:45
01-22-2014 15:45
Best Answer02-11-2014 04:52
02-11-2014 04:52
Shann, Did you get a resolution to this? Like you, I would also like to have two devices. I have had the One for over a year and love it, but I'm going on a cruise in a few weeks, and the Flex makes a whole lot more sense with all the water activities, etc. I would love to be able to switch back and forth. Also, if I do have to change to the new device, do I lost the data I have accumulated for the past year? Thanks.
02-11-2014 06:47
02-11-2014 06:47
Shann,
you are correct. You can only have one fit bit device per email account. What you could do is once the data has been update on one, you could type the data into the other one. I know it is a lot of work but you then would have it all in one. Not sure how fit bit could change it since they have it all allocated on a email account.
have a great day.
Jim
Best Answer02-11-2014 07:11
02-11-2014 07:11
