01-10-2018 14:04
01-10-2018 14:04
I have found that a good bit of the time I am awake is recorded by the Blaze as light sleep. One evening I recorded the time I work up and a time about two hours later during which I did not sleep. The Blaze recorded all but a couple of minutes of that as light sleep. I was wide awake. Any way the accuracy can be improved?
Best Answer01-11-2018 17:02
01-11-2018 17:02
If you go to settings, you should be able to change the setting to sensitive. See if that improves what you are getting as sleep. I will tell you that when I lay reading or watching TV, I guess I am so still that my tracker will record it as sleep as well. Oh if only 🙂
Elena | Pennsylvania
