04-13-2014 19:18
04-13-2014 19:18
how do i set my flex to sleep mode, and how do i turn it back to walk mode
Best Answer04-13-2014 19:33
04-13-2014 19:33
@marcb1time wrote:how do i set my flex to sleep mode, and how do i turn it back to walk mode
Sleep mode can be tricky. It needs to be taunt against your skin.
Five rapid and firm taps puts it to sleep. It buzzes, then two lights slowly fade to nothing. To check if it's still in sleep mode, tap and see two dancing lights.
In the morning, tap five times firmly and it buzzes and a single light shows when tapped. That light is to show the daily goal progress. Any tap when awake is to tell you your progress - one light for each 20% of your goal.
When you sync the next time, it ought to log your sleep.
click to read about sleep tracking
This link is to the Flex area where you will find the manual and related articles - click
04-13-2014 19:43
04-13-2014 19:43
Thanks so much !!
