05-02-2014 03:55
05-02-2014 03:55
can someone help me manually log my sleep the morning after? I put down the time I went to bed under "entered bed field" then the time I woke under "left bed field" I don't know if I should use same day/previous day and what is the 12 hr and 2 hr mean? After I enter the times it says I was in bed 19 hrs.
Best Answer05-02-2014 04:55
05-02-2014 04:55
@Jillo wrote:can someone help me manually log my sleep the morning after? I put down the time I went to bed under "entered bed field" then the time I woke under "left bed field" I don't know if I should use same day/previous day and what is the 12 hr and 2 hr mean? After I enter the times it says I was in bed 19 hrs.
@JilloHere is an example of my sleep last night.. which shows up in the day you awake, in this case today and 5 minutes before midnight is the previous day.
You can only add a manual sleep record if there has been a sync and within the time period of your sleep, and then only when you started your sleep yesterday.
Best Answer05-02-2014 04:58
05-02-2014 04:58
I woke this morning..computer synced fitbit...I can't manually enter for last night sleep?
Best Answer05-02-2014 07:28
05-02-2014 07:28
I believe you can log in your sleep manually. Go to the sleep log and delete the record and then readd it. Hope that works!
Best Answer05-02-2014 22:11
05-03-2014 08:10
05-03-2014 08:10
I think I have it logged so thanks for the help... ![]()
05-05-2014 01:42
05-05-2014 01:42
Just to address the second part of your question. The 12hr and 24hr is a clock preferance. 12hr is Standard. ie 10am, 11am, 12pm, 1pm.. The 24hr is Milatary time ie. 1100 hrs, 1200 hrs, 1300 hrs, 1400 hrs... For example if you had 24hr selected, and went to bed at (9:30 pm) then woke at (6:15 am) you would enter that time in the 24hr setting as: Entered bed at 21:30 woke at 06:15.
