09-04-2024 15:12
09-04-2024 15:12
I got the montly sleep analysis report
sleep profile as Parrot
My restorative sleep is at 75% and the typical and ideal range is way down the bar. I am confused since the bar starting range is at 58% and ending at 100%. 75% is marked on top of the line at the same place where I see 58% on the bottom of the same line. I am not sure how to interpret this.
Best Answer09-05-2024 04:31
09-05-2024 04:31
Hello @rajragh and welcome to the Community. I think there is a bug in the app. I use an iPhone and I see the same thing. I also see the same thing in the Sleep stability and Nights with long awakenings.
Do you use an Android or iPhone?
Laurie | Maryland
