I'm so disappointed with the "sleep" option. I thought it would actually pick up something on my wrist that determined when I am actually alseep and some information about the quality of that sleep. Instead it registers movement as being awake. False advertising. How can you track your sleep when you're required to turn the function on and off when awake. For that, this is useless. I also find the screen quality for the Premium option is awful. Being 65 I keep my screen view set at 100% or more. That isn't enough for Premium. And, if you try to increase the view, the text becomes a blur. Very bad design or, perhaps a bad choice of software??? Not sure what is a label and what is information on the sleep area of the Premium screen. But, no matter, it doesn't actually track sleep!
Best Answer@wantstowalk Which device do you have?
Welcome to the forums.
Best AnswerAre you turning the sleep mode on and off during the night? You don't want to do that. Turn it to sleep when you get into bed and take it off when you get up in the morning. If you get up during the night, leave it in sleep mode. That's how you know how often you were awake. Yes, it is based on movement, but I have found it to be pretty accuarate. If you are deeply asleep, you aren't moving. If you are restless, you aren't deeply asleep.
