Hello,
Can you use fitbit as an alarm to wake you up? I remember hearing from a friend that with certain devices you can program them to wake you up at the most appropriate time during your sleep cycle and that it will vibrate as an alarm
thanks,
Hi tbond,
Yes, there is a silent alarm that buzzes. On your dashboard, click the little gear icon in the upper right corner. Then click settings. Next, look on the left and click alarm. It will walk you through the short process of setting yours. Be sure to make sure you select a.m or p.m. Hope that helps.
Stephen
Do not let what you cannot do interfere with what you can do.--John Wooden, legendary UCLA coach
Accepting Solutions is your way of passing your solution onto others and improving everybody's Fitbit experience. Take a look here for more Fitbit help.
YES!
I use it to remind me to take meds and for my wake up call. However the more alarms you set the faster your battery will rundown. So I keep two alarms set all the time. They are most helpful.
