05-31-2016 09:57 - edited 05-31-2016 09:59
Hi,
I'm so disappointed with the Fitbit Surge. This is the 2nd fitbit I owned and have the same issue as the first fitbit....fogging screen from the inside. However, now I have a red light on. I didn't take my fitbit on vacation because it counts steps when I'm on my motorcycle. After I return from vacation, I charged my fitbit and noticed a red light but I still worked out for an hour at the gym and it seems to working fine. Now I'm looking at my fitbit and am starting to notice that the screen is fogging from the inside. The fitbit is not damaged at all and it wasn't fogged prior from going to the gym.
Has anyone have had this same problem?
I'm so disappointed with this product.
Best Answer05-31-2016 12:38
05-31-2016 12:38
17:30
05:32
MariamV
09-07-2016
17:30
05:32
MariamV
I'm on my 3rd Surge in 9 months. I asked for a downgrade as a repolacement to the Blaze but they keep sending me the Surge. Its obviously a bad design and they will lose me as a customer for good. Im sure I'll need to replace this one soon and will never buy another Fitbit again. I'll try Garmin. Its no surprise the stock is down to 15 bucks a share.
Moderator edit: format
Best Answer09-09-2016 10:52
09-09-2016 10:52
@wgdonohue welcome to the forums. I'm sorry to read about the bad luck you've had with your Surge trackers. In this case, Fitbit is not currently offering any exchange, downgrade or upgrade programs; and will honor the warranty by replacing your Surge with an alike tracker. If your tracker is fogging, please make sure that you thoroughly dry your Surge after every workout session to ensure no moisture is kept inside the tracker.
Also, if your Surge has the red light on the screen restarting it might be a good idea. If you haven't already please do the following:
After restarting your tracker, force a sync and keep an eye to your tracker's behavior. Keep me posted, I'll be around! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
Best Answer09-17-2016 04:15
09-17-2016 04:15
Best Answer09-19-2016 15:52
09-19-2016 15:52
@wgdonohue thanks for the update! Are you still having the red light on your Surge? Do let me know! ![]()
