01-07-2016 08:05
01-07-2016 08:05
01-07-2016 08:26
01-07-2016 08:26
Welcome to the community!
I'm not sure if you can do it from the Fitbit App, but I believe that you can from the website. Just do this:
Hint: You can go food log page from your iPad or iPhone, so it's not as if you can't do it from your device, just not necessarily the Fitbit App.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
01-07-2016 08:44 - edited 01-09-2016 23:45
add a food for today
then go to the previous day, and you're able to add food
edit : in the web dashboard
01-07-2016 08:26
01-07-2016 08:26
I hope this helps.
01-09-2016
22:24
14:40
VivisFitbit
01-09-2016
22:24
14:40
VivisFitbit
Hi Got it done thanks. It was a bit more complex because I using the quick calorie option which I could not find on the web version. So I posted any food on the past days, went to the IOS version, added the quick calories and deleted the foot I posted earlier. I think FitBit needs a bit or programming coordination between the versions. Steve Goppert Have a great day! 🙂
Moderator Edit: Personal Info.
01-09-2016
22:28
14:41
VivisFitbit
01-09-2016
22:28
14:41
VivisFitbit
Hi Got it done thanks. It was a bit more complex because I using the quick calorie option which I could not find on the web version. So I posted any food on the past days, went to the IOS version, added the quick calories and deleted the foot I posted earlier. I think FitBit needs a bit or programming coordination between the versions. PS: I goofed and replied to the wrong post. If a previous day has no postings, you cannot add to that day in the IOS version. Steve Goppert Have a great day! 🙂
01-09-2016 22:32
01-09-2016 22:32
Hi
Sorry I goofed. Your solution didn't work for me. Had to go to the web version. This is the solution that works/
03-29-2016 15:32
03-29-2016 15:32
Hello there guys! For those who are still having issues with logging your food, I recommend making sure you're running the latest app version. If you can force quit your app, that would be great.
Good luck!
