Hi, my Surge battery is draining very fast and today it was shown as almost being flat, so when I came home I immediately charged it. Surprisingly the battery showed almost fully charged in about five minutes. How is that possible? I think something is wrong with the bar which shows how full or empty the battery is. What to do to make the battery life longer?? I already tried to switch off back-light, heart rate monitor and it's not constant synching with my mobile. It seems my Surge is not working as it should be. Any advice is welcome. Thanks!! 🙂
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
http://help.fitbit.com/articles/en_US/Help_article/1799
If that does not help contact support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
Thanks for your advice, Wendy 🙂
I will try your suggestions and hopefully it'll work.
