03-07-2016 08:51
03-07-2016 08:51
I see the Alta has a "Reminder To Move" that goes off if you don't do 250 steps per hour. Is there any plan to include this in the Surge?
03-07-2016 09:12
03-07-2016 09:12
Someone has created a feature suggestion for this which you might like to vote for:
03-07-2016 09:52
03-07-2016 09:52
Thanks Steve, Went there and left my vote. It seems with the Surge buying a new tracker with the Reminder feature isn't an option as no other tracker has the GPS option.
Of course if the Surges processor or battery are already maxed then adding it to the Surge isn't an option either.
Best Answer03-08-2016 08:44
03-08-2016 08:44
Best Answer03-08-2016 11:12
03-08-2016 11:12
Given that the Surge is the most expensive Fitbit tracker available (and, therefore, arguably its premium model), there should be no reason that these types of features should not be integrated into the Surge absent hardware limitations.
04-06-2016 12:46 - edited 04-06-2016 12:51
@Pharmercist wrote:
It can remind you from the phone side like the pushes from challenges.
How do you add this? I have looked but see no options for notifications. I am using a Charge HR on an Apple phone.
Best Answer04-06-2016 12:58
04-06-2016 12:58
Best Answer04-19-2016 14:19
04-19-2016 14:19
Best Answer04-19-2016 15:08 - edited 04-19-2016 15:10
@cwil62 No way to have your Phone do that.
You can set alarms if you what they are under settings
Wendy | CA | Moto G6 Android
