02-04-2020 05:39
02-04-2020 05:39
I´m trying to measure my VO2 max, but it is too low. When inspecting data, I´ve found that gps data seems to be OK, but when checking them, I noticed that the reflected distance was aprox 4 km when real distance (via google maps, and also with other gps systems) was really aprox 6 km. How is it possible? Happened it only to me?
I cannot find anything to mend this bug...
Thanks
Best Answer02-12-2020 12:35 - edited 02-29-2020 09:39
What exercise are you doing @ERit walking uses the stride for distance, even when using GPS.
What type of unit are you using to measure VO2, your Surge is not able to measure this.
I'm not sure where VO2 fits in with the GPS.
