05-26-2016 03:48
05-26-2016 03:48
05-31-2016 07:50
05-31-2016 07:50
Welcome aboard to our community @Knightsb. When you start an activity with your Fitbit Surge, it will give you the option to pause your exercise as you mentioned. It wont matter how many time you do this as long you don't press the stop button in the upper right corner. Also keep in mind that the tracker will automatically stopped your exercise after 15 or 20 minutes in pause so if the pause is longer than this, the tracker will finish your ride.
Unfortunately there is no way it recognized your pauses automatically or make longer the time it stopped your exercise. Although there is an idea in our Feature Request board that is quite popular, requesting the same function. Perhaps is of your interest, so here is the link for you to share your comments and add your vote and make more popular the idea.
Hope this helps a little and see ya around my friend.
05-31-2016 11:48
05-31-2016 11:48
10-09-2016 09:02
10-09-2016 09:02
11-12-2016 09:55
11-12-2016 09:55
Hmmmm... this is strange. I'd recommend restarting your Surge by doing these steps:
Once you've done this, test your tracker again to see if your Surge works as it should when using the Pause option. Keep me posted @Loluke66!
