07-20-2017
09:06
09:49
YojanaFitbit
07-20-2017
09:06
09:49
YojanaFitbit
Hi,
The screen on my Surge developed a black spot a few weeks ago that grew progressively bigger. Then the screen started flashing and now it is effectively a dead screen.
The underlying device is still working as it will measure acitivity but looks ridiculous on my hand, just a big balck blog on a grey screen, so it is pretty useless and I have basically stopped using it.
is this an known problem and is ther a solution?
Thanks,
Donal
07-20-2017 09:48
07-20-2017 09:48
We are very pleased that you have joined our Family here in the Forums @Boatman777! ![]()
Thanks for the information provided! For you to have the best possible experience, I've created a Support Case on your behalf. Keep an eye on your inbox! I'm sure they will be glad to help you with this.
Let me know if you need more information! ![]()
07-20-2017 09:48
07-20-2017 09:48
