moi aussi j'ai le meme probleme ca fait 15 jours que je suis entrain de configurer mon fitbit surge avec mon android a500h ver 6.0.1 et mon pc systeme windows 7 mais je n'arrive pas meme avec le help fitbit
Best AnswerHi. Not sure if I'm experiencing what Kayla is experiencing but with me:
- phone: OnePlus 3T (Android OS)
- the phone will pair with the surge.
- when adding device (in app) the phone will fail, always. (So I feed in the 4 digit code displayed on the surge and always get the same failure message and asked if the device is close to the phone... It's 1 centimeter away from it).
Furthermore, the phone used to be connected to device but I had to remove it as it wouldn't sync.
Your help will be greatly appreciated 🙏
Thanks
Guy
