08-11-2017 14:53
08-11-2017 14:53
Not yet managed to get beyond "Lets Get Started" screen . Have registered & paired the tracker with my Windows 10 laptop . Tried several restarts & charged via laptop but unable to see any charge status on the tracker screen . Am a bit wary of overcharging / leaving it charging overnight . Have deleted & re-installed Fitbit App . Any other options to try ??
08-11-2017 15:17
08-11-2017 15:17
Download the connect for pc not WINDOWS 10 app from fitbit and try that. I had issues with the window 10 app couldn't get my surge connected, once I downloaded the connect for pc I had no problem. You can also set it up using your smart phone if the phone is a comparable model Good luck!
08-11-2017 17:11
08-11-2017 17:11
Thanks for your swift rely @Redmoonstar - I am connected & ready to go , problem is just the frozen screen .......
08-13-2017 04:26
08-13-2017 04:26
Fitbit Support are dispatching me a replacement Surge . Thanks to all for your interest .
