11-26-2016 21:35
11-26-2016 21:35
Best Answer11-27-2016 00:38
11-27-2016 00:38
Welcome to fitbit!
I think your fitbit is working fine.
As well as tracking calories you burn through activity, your fitbit also tracks your BMR calories. These are the calories you burn just keeping your body alive (even when asleep). They are calculated from your profile settings (age, weight etc) so you needn't be wearing your fitbit to get them. What you are seeing is the total BMR calories since midnight. There's more information on this here:
Best Answer11-27-2016 05:19
11-27-2016 05:19
12-02-2016 06:42 - edited 12-02-2016 06:47
Fancy seeing you here @Jiku_1994! If you found this post really helpful, I invite you to mark @SteveH's post as the solution. Marking posts as solutions is a great way of thanking another community member while also highlighting their solution so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solution. ![]()
I’ll see you around the Community! ![]()
