01-11-2017 09:32
01-11-2017 09:32
I've started trackin my food on the Fitbit app also (used to use my fitness pal).
My fitness pal takes into account the calories burnt and gives you these back to eat, but the Fitbit app doesn't?
Any ideas?
01-12-2017 02:39
01-12-2017 02:39
Anyone have any ideas on this please?
01-12-2017 06:10
01-12-2017 06:10
Hello sweetie @Cerriann1t. I suggest to keep using you MFP Account to keep tracking your food, you can link it to your Fitbit Account following this instructions in a computer. So, you will keep using the amazing options that MFP has, plus the activity recognition from your Fitbit Account. Additionally I recommend considering starting a Food Plan in case that you haven't do so. You will find the option in your online Fitbit Dashboard, you can check on a computer the tile "Calories In vs Out". For more information about starting a Food Plan check this information. ![]()
Hope this helps! ![]()
