@getfitjane A warm welcome to the Community! Thank you so much for the details as well for the screenshot. That's completely weird. I would like you to answer the following questions: Did you log any activity that could gave you some calories? How many calories burned did you get at the end of the day? Has this happened again? Were the calories burned just going up without you doing anything? Also, when did this happen, I noticed you sent an screenshot from Monday 23rd and Saturday June 4?
Keep me posted.
Hi Silvia! Thanks for the welcome.
I actually did not have the Surge on at all - and I think that is where the trouble was.
When I took off my Surge, I think it fell beside the power supply box for my laptop, which, as we all know, can get very hot. I think somehow the Surge detected the heat from the power supply and simply input the heat as calories burned.
It was VERY weird but thankfully has not happened again. And while I do have a morbid curiosity to test this as a theory, I am not willing to risk my Surge in the process.
The good news is I did call and email support about this, so hopefully the techs at Fitbit will look into this and see if it is actually a thing, so at the very least they can put out a warning or some such.
My cautionary advice is, be careful where you set your Fitbit when you take it off! Avoid putting it near high-heat items like a charging phone or pwer supply.
09:33
04:57
07-02-2016
09:33
04:57
Thank you for your reply @getfitjane! I appreciate the advice and it is true, is better if you don't leave your tracker, any Fitbit tracker, too close to a power supply for a long period of time, not because it'll calculate that as calories burned, but because the Surge hardware can be damage. On the other side I'm glad to hear that this issue didn't happen again. But if so, let me know, and I will investigate further.
I'll be around!
