03-14-2016 11:51
03-14-2016 11:51
I don't want time / date displayed. I just want the distance I walked displayed on the watch face. Is there a way to do that? Seems I must access the app to find that data out.
Best Answer03-14-2016 14:39
03-14-2016 14:39
Welcome to the Fitbit Community @jdgiuliani. It's great to have you here. There is actually no option to customize the Surge to display your distance traveled instead of the time and date. You are welcome to place a suggestion in the Feature Request board. If there is any update it will be communicated as soon as possible.
To check out your distance you can swip your Surge display through the different activities you performed until you see your distance.
Thanks for stopping by, see you around. ![]()
