05-10-2016 11:05
05-10-2016 11:05
Best Answer05-24-2016 10:42
05-24-2016 10:42
Hello @Pisuta, welcome aboard to our community. My first suggestion would be to review your exercise shortcuts. Make sure the exercise of your choice are selected on your device settings.
If this is not the issue, then I recommend a restart on your Surge. In case you need the steps to do a restart, here is what you need to do:
1. Press and hold the Home and Select buttons (left and bottom right) for 10 to 15 seconds, until you see the screen flash or start to dim.
2. Let go of the buttons.
3. After your screen turns completely off, wait 10 seconds and press the Home button to turn your Surge back on.
Hope this issue does not longer persist and let me know how it goes.
Best Answer05-24-2016 11:43
05-24-2016 11:43
I *think* I saw a setup feature somewhere which allows you to tune which exercise modes you can select; have you tried to configure other modes?
