Can someone with 8 inch wrist fit in Surge Small size?
I bought a Surge Small but not sure if my 8 inch wrist is too big for it or not. If it is, are there any ways to replace the strap with a larger one?
I can't return it because I bought it on eBay. Also, does the manufacturer 1-year warranty apply to ebay purchase?
2 REPLIES 2
I think you are going to struggle with the size. Here's the fitbit size guidelines:
Unfortunately, the strap can't be replaced as the electronics are built into it.
Equally unfortunately, eBay are not an authorised seller so I don't think you will be covered by the fitbit warranty.
Sorry to be the bearer of bad news.
@acercode Welcome.... I had to use this Garmin extender strap on my small band Surge. Worked perfectly and allowed the sides of my wrist to breathe.
Colin:Victoria, Australia
