05-10-2016 06:56
05-10-2016 06:56
I can't sync directly to my computer using the fitbit dongle that came with my Surge.
-I've installed the Fitbit app for Windows 10
-I don't have anything installed called Fitbit Connect
-My laptop doesn't have native bluetooth as a functionality
-I've removed all other bluetooth dongles to rule out signal interference
-I've tried using a USB 3.0 and USB 2.0 port
Any ideas?
05-10-2016 07:29
05-10-2016 07:29
If you have a mobile device that you use to sync nearby, turn it off and see if you can sync then....
05-10-2016 07:29
05-10-2016 07:29
05-10-2016 07:36
05-10-2016 07:36
