09-28-2018
11:27
09:51
YojanaFitbit
09-28-2018
11:27
09:51
YojanaFitbit
Can't get my surge to change to uk time zone
Moderator edit: Updated subject for clarity.
10-17-2018 09:48
10-17-2018 09:48
Good job @AnneF.! I think that was a great way to solve the issue. Thanks for replying though. ![]()
Please feel free to come back at any time, we try to take care of all the members of our family.
Have you checked our Discussions board? If you're into Fitbit and fitness you may enjoy other users' comments. Check this board Looking for Fitbit Friends? Find some here! And have some fun interacting with other users!
Keep stepping around in the Forums! ![]()
Best Answer09-28-2018 21:54
09-28-2018 21:54
Welcome to the forums!
Try this
On the computer: Go to the Dashboard and click on the gear and choose settings from the drop down. Scroll down to time zone Change it to a different one. Sync it. Go back in and change it to the correct one and sync again
Phone: Click on account upper top right looks like an envelope. Scroll down to advanced settings and do the same as above
Device will need to sync before it changes
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
10-03-2018 09:49
10-03-2018 09:49
How you doing my friend @AnneF.? Welcome! Thanks for the help @WendyB. You can also check these steps. It should be working just fine after this. ![]()
Keep me posted with the outcome!
10-05-2018 04:48
10-05-2018 04:48
I’m having the same issue. I have followed all tips given but it is still stuck in the Greek time zone
10-10-2018 13:51
10-10-2018 13:51
Welcome to the Forums @Cezla!
Thanks for trying those steps. Did you checked these steps already?
1. On the Setting on your phone
4. Tap "General."
5. Tap "Date & Time."
6. Ensure that "Set Automatically" is ON.
7. Reopen the Fitbit app. The issue should now be resolved.
Those steps usually fixes the time. Can you please double check?
I'll be around.
Best Answer10-10-2018 13:55
10-10-2018 13:55
10-17-2018 09:48
10-17-2018 09:48
