08-19-2021
12:42
19:16
08-19-2021
12:42
19:16
surge doen’t appear in my bluetoothlist ipone 11.
I use also an Ionic on the same phone and account
Best Answer08-20-2021 08:51 - edited 08-20-2021 08:54
Hi @Prowolf - there are a couple things I’d suggest you try:
Let us know if this helps. You may want to look at this community discussion thread regarding the same issue you are experiencing.
Best Answer08-26-2021 16:27
08-26-2021 16:27
Surge doesn't need to be paired with or even show up under Bluetooth devices to work with the Fitbit app.
Best Answer08-26-2021 23:17
08-26-2021 23:17
