02-15-2017
21:35
06:03
YojanaFitbit
02-15-2017
21:35
06:03
YojanaFitbit
I have tried post the app on my Window Phone and on the web page to install my Purge. After pairing the unit successfully there was no option to get it into the Device Viewer. The mobile App sugestst to use the web page and the web page doesn't seem to have a function to add the Surge Watch Tracker.
Please advise
Moderator edit: Clarified subject.
02-25-2017
06:02
10:59
02-25-2017
06:02
10:59
Hi @karlos7! Please receive a warm welcome to the Fitbit Community! Thanks for jumping in @Julia_G, great clarification! ![]()
@karlos7 I would like to know which Windows phone your using. Also, check the requirements to proper sync with mobile devices. After doing so, please try the next steps to finally setup your Surge:
Hope this helps! ![]()
Best Answer02-16-2017 01:37
02-16-2017 01:37
Hi, @karlos7, on your Windows Phone you need to add your Surge via the Fitbit app, NOT your Bluetooth devices screen. On the main screen of the app at the bottom select the "account" icon. That's the small square with 3 lines and a circle. On the next screen choose "set up a device". Hopefully it should then find your Surge.
02-16-2017 02:55
02-16-2017 02:55
02-16-2017 03:03
02-16-2017 03:03
Hi, @karlos7, no attachment...
02-25-2017
06:02
10:59
02-25-2017
06:02
10:59
