03-28-2016 05:42
03-28-2016 05:42
Best Answer03-29-2016 17:13
03-29-2016 17:13
Welcome to the Fitbit Community @Cantreadtexts. It's great to have you here. If you haven't done it already, please restart your Surge. You should be able to swipe between received messages from now on. Please be aware the restart will delete previous messages on your Surge but you still can see them in your phone.
If the above doesn't work, it could be a good idea trying the following:
- Log out from Fitbit app
- Go to your Phone settings > Fitbit app > Clear Cache > Clear Data
- Close the app
- Log back into the Fitbit app and try again
Catch you later. ![]()
04-06-2016 08:21
04-06-2016 08:21
Best Answer04-06-2016 18:47
04-06-2016 18:47
Best Answer04-07-2016 15:28
04-07-2016 15:28
Thanks for the update @Cantreadtexts. I would recommend following these instructions.
If the above doesn't help, try removing your Surge from your account by going to your Device settings and clicking "Remove This Surge from your account". Then, set it up as a replacement device and set the text message notifications once again.
Keep up the super stepping. ![]()
Best Answer04-08-2016 06:30
04-08-2016 06:30
Best Answer04-08-2016 14:08
04-08-2016 14:08
@Cantreadtexts Please be aware this is actually not a common issue. Since you have tried the workarounds that should resolve the issue I would recommend contacting Customer Support. Let them know the troubleshooting steps performed so they can move forward providing further assistance. They will let you know about any update.
Thanks for stopping by, see you around. ![]()
Best Answer04-09-2016 22:17
04-09-2016 22:17
Best Answer04-10-2016 12:47
04-10-2016 12:47
@Cantreadtexts Thanks for your time while dealing with this situation. Let me know if you don't hear from them in the next days.
Hope to see you around more often.
