Changing stride length does NOTHING
My new surge registered only 2.26 Miles while my treadmill said 3 miles, so I went in and changed my stride length. I tried many different stride lengths, synced them, tried running more and compared it to the treadmill and NOTHING changed! The distance I ran according to the surgewas the same no matter how long my stride length was! I'm about to return this thing.
3 REPLIES 3
How accurate was your step count? Stride length is only one component of the distance calculation.
For what it's worth, I think Fitbit have always recommended that Treadmill work be logged manually. I'm sure the calorie calculation accuracy has improved over earlier trackers due to the HR monitoring but an HR monitor will clearly have no impact on distance accuracy.
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
Thanks. How do you enter the run manually? Also, when you use gps to record a road run, does it use GPS to determine distance or does it use steps ?
the purpose of a GPS is
1) find a way. not applicable on Surge
2) measure distance, time, and so on.
