I found this suggestion on another website and it worked!! Plug your fitbit into a computer or outlet. press down on the side button for 10 - 15 seconds - you will see the model # for a moment. unplug, then try syncing again. This worked for me - I have a Fitbit Charge HR. (Uninstalling the fitbit ap and reinstalling did not help). Here is the link to the article:
http://www.thequickwayto.com/2015/08/how-to-fix-tracker-not-syncing-problem-with-fitbit-charge/
There is an update being released slowly for the Charge HR, it's in the Charge HR threads.
13:54
08:18
05-03-2016
13:54
08:18
Welcome to the Community @Fiona40204! I'd like t know if you could perform the firmware update to make your Charge HR sync as per @Redmoonstar and @Kellyp43 advice. You can also try to set up you tracker as a new dvice:
I posted the instrucions for an iOS device, let me know if you have a different phone.
