While experimenting with creating Custom Activities, I have made several such activities. After refining them to reflect actual workouts for which I can compare, I realize that many are no longer appropriate. My question: how do I delete no longer used Custom Activities, and in other cases, how do I modify the names of Custom Activities that I have already logged?
Charlie
Allow me to help you @CAR49ers! To delete a custom activity, do the following:
- Go to your Dashboard > click on log
- Click on activities > scroll down and you'll see at the right corner the custom activities
- Finally, hover the mouse over the custom activity that you want to delete
- Click on the trash can
Note: Keep in mind that just the ones that have the trash can on the right side, are the ones that you created.
Regarding your question about modifying the names, currently it's not possible to edit them. You can just delete them and log the again. You may want to post this idea in our Feature Suggestion board, because those suggestions are viewed by our engineer and developers.
Hope this helps! ![]()
Thank you Silvia, that is what I thought...Bummer! I will look for the Future Suggestions Board, as I have a couple of ideas that would make things a little better. Thanks again.
Charlie
@CAR49ers Thanks to you.
Quick helpful tip regarding posting your ideas: Keep them separate so everybody has the chance to vote for each idea individually. Look for your idea, it may has been posted and you just need to vote for it.
Thank you so much for posting your suggestions. ![]()
